Posts: 18   Pages: 2   [ 1 2 | Next Page ]
Previous Thread This topic has been viewed 39253 times and has 17 replies Next Thread
Strikkie
Holland
building a roof
I there,
I've checked the forum and I found a question regarding the roof and I downloaded the pdf file but when I create the roof it is positioned in the groundlevel and it must be placed on the top of the wall.
Does anybody has got an idea how to do that?
thanks in advance for the help.
Reg,
[Dec 8, 2015, 7:33:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Re: building a roof
You could just lift the roof (e.g. Furniture, Elevate - or use the little blue arrow in one of the corners). But, as you do not want the roof in the way, it may be better to use a new level for the roof (Plan, Add level) at the right elevation and place the roof there. ok
[Dec 8, 2015, 10:11:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Strikkie
Holland
Re: building a roof
I just found a way to lift/elevate something yes okay that's one
Now I need to find a way to create a shape so that I can tilt the roof and make it slanted.
[Dec 8, 2015, 1:47:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg
Re: building a roof
Have you checked out the Sloping Ceiling tutorial?
http://www.sweethome3d.com/slopingCeilingGuide.pdf
That should help.
Hawk
[Dec 8, 2015, 9:44:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: building a roof
In addition to hansmex' tutorial mentioned by HawkDawg, there is also a useful blog post: How to design a sloping ceiling with a window and Arun's approach to create a Simple Roof in SweetHome3D. If you do not want to construct yourself, there are roofs on the 3D models page too and some in the SourceForge pages, such as these.
[Dec 9, 2015, 8:16:09 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Strikkie
Holland
Re: building a roof
Hi Hawk,
Thank you for the response but at point 6 and 7 in the tutorial it's written that you need to create a room but I can not lift the room to a certain level, you can only lift furniture...
but thanks for the info.
[Dec 9, 2015, 9:17:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Strikkie
Holland
Re: building a roof
Hi Okh,
Thank you for the info, i'm going to have a look on this page.
keep you informed on the outcome.
bye
[Dec 9, 2015, 9:18:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Strikkie
Holland
Re: building a roof
Hi hawk, http://sourceforge.net/p/sweethome3d/d-models/372/
this is the roof I'm looking for, did you managed to get the roof filled?
reg.
[Dec 9, 2015, 9:37:27 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg
Re: building a roof
Hi Hawk,
I gave some help on how to do that in another topic you have.
http://www.sweethome3d.com/support/forum/viewthread_thread,3615
reg.
Filled? What do you mean? Textured? Models don't always texture as well as walls or models textured in a 3D Modeling program.
Hawk
[Edit 2 times, last edit by HawkDawg at Dec 9, 2015, 11:36:44 AM]
[Dec 9, 2015, 11:33:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Strikkie
Holland
Re: building a roof
Hi Hawk, please check your post and you'll know what I mean
[Dec 9, 2015, 1:00:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2021 eTeks - All rights reserved
