As I've say already in my previews post
<<Which one?
Give me some point or some graphical picture of what you want.
Don't forget to indicate the name for it.
I can't promise but I try to help You.>>
it remain as truth for every one including You.
Usually I like to help (if I can).
2D Symbols
This topic has been viewed 177311 times and has 42 replies
- dorin
- Advanced Member
- Country: Vatra Dornei, Suceava, Romania
Re: 2D Symbols
Re: 2D Symbols
Hello,
I have on this day create a Windows VB.NET application.
Based on the Linux script Create2DSymbols.sh
Only for create a 2D Object bibliothek.
Is the PNG picture 250x250 px then is the object 25cm in SH3D!
Testing and give me a answere.
Github
Github
Re: 2D Symbols
Is this thread still active? I'm asking as I'm trying to import the Belgian electrical symbols available in PNG format at https://www.zelfverbouwen.com/wp-conten ... mbolen.zip. I have used the Windows VB.NET application from XPcRUSHER in this forum to convert some symbols to .sh3f. However I don't see them in Sweet Home after import.
Any suggestions how I can get the AREI symbols in Sweet Home?
- dorin
- Advanced Member
Re: 2D Symbols
At this moment I can't help you because I'm far from any computer.
At end of next week I will make that library for you.
- dorin
- Advanced Member
Re: 2D Symbols
Your library are here .
Re: 2D Symbols
Thank you very much, this saves my day!
Re: 2D Symbols
Ciao scusa la mia ignoranza ma io ho fatto tutti i passaggi da te descritti ma lla fine mi ritrovo una cartella con i png e i 2 file di cui uno modificato, a questo punto tu scrivi ZIP la libreria; cioe? devo compattare tutta la cartella in un formato zip? e poi come la importo in sweet home 3 d?
Spero che mi possiate aiutare, grazie
- dorin
- Advanced Member
Re: 2D Symbols
Sorry for the late response. I've seen your question only today.
1. A furniture library or a texture library is basically zip archives.
2. So, you have to change the extension .zip to .sh3f or .sh3t
3. Starting with version 1.5.3 I've made a bash script Create2DSymbols.sh to simplify this process under linux which is inside the package.
4. While it's not quite that simple I could made it for you like I've already done for others fiends here.
Re: 2D Symbols
Hi, Dorin! I'm writing here just to thank you! Yor instructions and packages help me a lot. Probably I will put here a Library for Brasil standards 2d Electrical (when finished).
- dorin
- Advanced Member
Re: 2D Symbols
