Re: Sweet Home 3D with Java Web Start not working in java7
This error means that the JNLP file you deployed isn't the same one as the one included in SweetHome3DJavaWebStart.jar file (see target javaWebStart in build.xml )
It's normal that it works with Java 6, since the verification with JNLP-INF/APPLICATION.JNLP file was introduced with Java 7.
Please give me the right solution
Do you really think that if I knew the solution, I wouldn't give it??? I gave you the hints I could guess, it's up to you to go forward now.
