Re: Pan tool in 3D and 2D view?
One small request. Could we preserve the setting for the hiding feature across sessions? I'd prefer it to be off on startup while it is still at the proof of concept stage, but at the moment it is default on whenever starting SH3D.
Italy
I've published the new version, here are the improvements: - almost fixed the polyline selection bug (now only happens while creating the polyline); - selected objects are never hidden; - the hiding behaviour is much better.
Hiding criteria Hiding is now performed based only on the X-Y plan. Hiding using a polyline works as before, the only difference is that now the wall detection is made on the whole length, giving much consistent results even with long walls. Automatic hiding works as follow: - if the camera rotation centre is within a room, a hiding threshold is built by shrinking the room shape. This produces very good results, which are affected mostly only by the camera orientation. - If the rotation centre isn't within a room, the hiding threshold is a straight line parallel to the screen and passing through the rotation centre. This gives good results when rooms aren't defined yet.
Hmmm... Did you mean to disable the return to center when clearing any selections in 1.4? I kinda preferred the previous (1.3.3) behaviour, but I'm not wedded to it.
Italy
No, I didn't mean to change the return to center behaviour, this occurred by mistake while optimizing the code. I'll fix it in the next release which will bring a new feature too.
Finland
@Daniels118 Thanks for great pan tool! I feel it very handy, especially when jumping constantly between SketchUp and SH3D. With version 1.3.x my models easily escaped to infinity when using zoom. Version 1.5 has not this problem. Hide obstacles help to create unique views not otherwise (at least easily) possible.
@Daniels118 Just a side note, you should probably create a new top-level post in the "New versions" forum. That appears to be where all the other plugins are posted, and updated. nThis wonderful little addition would get more exposure there I think.
