Total posts in this thread: 52
Posts: 52   Pages: 6   [ 1 2 3 4 5 6 | Next Page ]
Previous Thread This topic has been viewed 9528 times and has 51 replies Next Thread
hfrmobile
Lower Austria
Pan tool in 3D and 2D view?
Can't find a "pan tool" (similar to Google SketchUp for example) for moving the model in 3D/2D view. This would be specially useful when having a model which is long but not very width.
e.g.
--hfrmobile
[May 27, 2014, 6:03:09 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Pan tool in 3D and 2D view?
In the plan, the pan tool can be activated with the Plan > Pan menu item or temporarily with the space bar.
In the 3D view, you will be able to move sideways in the coming version 4.4 when you're in Virtual visit mode (see here).
[May 27, 2014, 6:07:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
hfrmobile
Lower Austria
Thank you for your answer!
Well, in 2D view its the same when using the scroll-bars, right? But the trick using the space bar is useful, thanks!
In the 3D view, you will be able to move sideways in the coming version 4.4 when you're in Virtual visit mode.
Well, this is, more or less, already the case when moving the figurine.
A pan in 3D view (aerial view) would be useful since at the moment it is not possible to zoom in to the bathroom for example:
[May 29, 2014, 8:29:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
In Aerial view panning doesn't make sense, because you can only turn around the center. Note that if you want to change the center of rotation, you can read the FAQ Is it possible to manually set the rotation center of the 3D view in Aerial view mode?
[Edit 1 times, last edit by Puybaret at May 29, 2014, 9:34:13 AM]
[May 29, 2014, 9:30:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
hfrmobile
Lower Austria
The option "Aerial view centered on selection option" does the trick, thank you!
Maybe a bug: Go to point of view (of a stored point of view) does not change to the correct level (if the model contains more than one level).
To put this in other words: Storing a point of view in Level 3, then I change to Level 1 and select the point of view in level 3. But the level 1 remains ...
[Jul 19, 2014, 10:59:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
You can use this plugin:
https://sourceforge.net/p/sweethome3d/plug-ins/39/
Disclaimer: I'm the developer of the plugin.
[Nov 17, 2021, 9:09:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sjb007
THIS IS AWESOME!!!!!
Thank-you, thank-you, thank-you.
Just one small niggle: If I pan, then orbit, the new point of rotation sticks and it works as hoped. If I pan, then zoom (mouse scroll wheel), the view jumps back to the previous point of rotation, whether that is the center of everything, or the center of the current selection.
[Nov 19, 2021, 12:29:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
I really appreciate your enthusiasm :D
I tried to reproduce the problem but without success, however I have found the behaviour you described happening when the selection changes, so I have updated the plugin to correctly handle this case in 2 different ways, based on the the option "view centered on selection". Try the new version, if you still experience the same problem you may record a small video to let me understand the exact steps to reproduce.
Thank you and best regards
[Nov 20, 2021, 10:09:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sjb007
See https://youtu.be/nq00He4oz_4
I did notice that navigation keypresses in the 3D view also "reset" the panning. It may be that the mouse scroll wheel up/down action are treated more like keypresses than mouse button actions.
[Nov 20, 2021, 2:43:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Thank you for the video, it is very well done :)
However this behaviour doesn't happen for me using the scroll wheel, it only happens using key navigation (WASD). I think it could be due to a different underlaying software (i.e. operating system, java version, etc...).
If it isn't too much effort for you, please report the following:
- Operating system;
- Type of SH3D installation (installer/java web start/ runnable jar);
- SH3D version;
- Java version (only needed if you aren't using the installer version).
Little anticipation
I'm currently working on a new feature to automatically hide any wall between the camera and the center of rotation, I think to release it as an optional feature.
[Nov 21, 2021, 7:47:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2022 eTeks - All rights reserved
