Total posts in this thread: 2
Previous Thread This topic has been viewed 1996 times and has 1 reply Next Thread
2Dhome
How to put two walls exact distance apart?
If I have two parallel walls, how do I make them some exact distance away (e.g. 4 feet 2.75 inches) from each other?
In visio, there is a tool that can be attached to both walls, then a distance can be typed into the tool to push/pull the walls to that exact distance. I don't see a similar tool in sweet home 3d. The only way I see is to use "modify wall" and enter coordinates for the walls.
What happens if instead of two walls, I want to adjust the distance between two rooms I already drew? There seems to be no way to enter coordinates for a room. I can drag the rooms to an approximate distance apart but how do I get it to be exact?
[May 9, 2014, 4:02:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How to put two walls exact distance apart?
Go to the Documentation page and download the Plug-in tutorial.
Install the AdvancedEdit plug-in.
This will add a function that allows you to edit the points of a room.
[May 9, 2014, 8:18:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
