Re: Sweet Home 3D 4.4
The Beta 10 released this weekend fixes some bugs related to unit conversion in Virtual visitor and Compass dialog boxes, and attributes 2 GB of max memory to Sweet Home 3D run with Java Web Start under 64 bit Windows and Linux systems. Sorry, I didn't find a way to increase the max memory under Mac OS X 64 bit too (sounds like a bug that appears only under that system), but if needed, there's always the solution to use installer version and set the max memory. Under Windows, the JRE launched by default seems to be the 32 bit version if you installed both 16 and 32 bit JREs. This max memory now appears in the About dialog box for information.
Nice improvements, and no trouble (4.4 Beta 10 Java version 1.7.0_55 / 32 bit / 0.6 GB max): - 3D window did not update changes made in 2d (happned twice: move door / change level), but could not reproduce. - Once the plug-ins did not load, could not reproduce. - Is the web-start security warning: "The application has requested permission to establish connections to www.sweethome3d.com. Do you want to allow this action" new? Could be my Win 8.1 settings, I guess, I just cannot remember seeing it before.
In short - nothing
Very happy with the searchable textures - and recent textures.
INDIA
Sorry for the delay. At last I found some interesting this.
Do you mean I should reduce refraction to 8 for better results?
No It was my mistake, when reducing reflection & increase refraction It reduces black dots slightly, not Removes completely. After a lot off experiments in between 3ds-max, SweetHome3D & sunflow I got the result. Different Glass materials applied with different obj shapes & render it in 3DSMax Mental ray
Then this objects imported into SH3D & render different method by tweaking caustic & reflection, but got the error image.
Then I using default SH3D files & started tweaking Object I got this result.
The problem is so simple. To get the result I change the transparent object material.-Furniture->Modify->Material. If transparent/Glass color = Green by default then I go modify->material ->color =Green ,then Render. It give the result what I need exactly. Come to the point, If the object is transparent(Object.mtl d<1) Photorenderer .java failed to set shader dependent parameters like specular, glossyness, shaderName-uber at its default or failed to export these values to sunflow.
When a new value is applied it over returns the default values and works fine. See: No shader.
A new color/Texture is applied. But it failed some times to apply texture when d <0.1. In this image all Glass materials are failed to render
Its a nice idea if texture material is white,Object become fully transparent & if black it transmit light inside to the object(only if d<1). I think the bug located from here to here Sorry I'm not a programmer. I have a little knowledge in C++(SH3D introduce me first Java. Thxs a lot) . Here is some more render output&work files .
I just released the Beta 11 that improves the saving procedure to avoid duplicate content in .sh3d files. Please be cautious to save your files in a new file (at least the first time), to ensure you won't lose any data. I trust what I programmed and tested on different files, but you never know, even if the risk is very small. Please test it on the files you may have and confirm you didn't have problems.
sree.arun.kr, thanks for your tests. I'll look again if I can improve something in exportAppearance method, but I fear the problem comes from elsewhere….
Then I got the result : glass material render properly Then I go search about OpticalDensity and come up page OBJLoader.java I think in this page you are not described the vales&limitation.(I dont know java programing) ie, Ni , min value = 0.001 max value = 10. (Internet search result ) & this will create the improper value Error. glass & mirror OpticalDensity strength difference. I hope this will help you to fix the bug Thank you.
Tonight the Beta 12 will allow you to test some new features I added to the Online version: - It's now possible to import from .sh3d files (use the 6th button in the tool bar), and the program checks what 3D models and textures are available on the server to reduce home data length saved on server. - The home data length is checked each time you try to save, and a warning is displayed if this length is larger than the limit on the server (still set at 3 MB). - I added a Delete button in the Open dialog box to let you delete homes saved on the server. Please, test these features (hope it will work under Linux too). Of course, avoid to import hundreds of files and don't forget to delete the ones you don't need online anymore (exporting them to a .sh3d file if needed). This service is not for backup purpose!
sree.arun.kr, thanks for your findings. So you mean that Ni shouldn't be used directly, and by ignoring its value there's no more problem? Why do you propose 2.5 rather than 1.55 the eta of the glass?
Lower Austria
Seems to work but my model is still to big.
Even I get the following message The home data length (3.3 MB) is larger than the maximum length accepted by the server (3 MB). Delete some furniture and/or background images to reduce the length of saved data.
the model will be loaded but can't be stored. Anyway, it is pretty cool that a 16.8 MB model can be reduced to 3.3 MB!
Thank you both for your feedback. The 6th button displays the icon and is available only if you login.
I improved the logic of files checking/saving in the Beta 13 of the Online version, and the furniture list will display imported furniture in italic in the online version, to help you find these objects when the home data size is too large. Showing a file size indicator could be nice too, but let's see first how the import feature is used…
It's not really reduced. In the online version, the data of a home comes from: - the drawing coordinates of furniture, walls, rooms..., - the furniture and images imported by the user, - and the redistributable 3D models and texture images available on sweethome3d.com server (through free 3D models page for example). The difficulty was to try to find as much as possible uses of redistributable 3D models and texture images without downloading everything, to reduce the size of the remaining data in a home. A smaller size ensures that saving (i.e. upload to the server) time will be reasonable for the end user, that bandwidth use won't increase too much on the server and that home data won't occupy too much space on the server too. For the programmers interested in the subject, I added SHA-1 digests of 3D model and image files in the online libraries and compare them with the digest of each model and image used in a home file at importation time. If two digests are equal, then the model or the image in the file can be replaced by a reference to the same file on the server (see resolveObject method in HomeObjectInputStream and the new class ContentDigestManager). So, if you followed everything, 3.3 MB is the size of (compressed) data that couldn't be found on sweethome3d.com server.
Maybe a FTP support will be an option?
What do you mean?
