Re: preview problem
my graphic card is intel(r)HD Graphic 4000.... does it support sweet home ? If Sweet Home 3D was able to run with your graphics card once, I don't see why it couldn't anymore.
i increased the memory to 1G.... updated the graphic card ... but when i open the file it stops working. I don't know if it's what you tested but trying to run set the max memory to 1 GB would probably require to run the program in 64 bit with the Jar executable file. Is it what you tested?
another question please how can i reduce the file size in the first place? Trees are the biggest objects. So if you used many of them, try to remove some. If it's not the case, it will be more difficult to find out, you could explore the sh3d file with a zip utility to find the biggest files (be sure to create a backup of your sh3d file first), but as their file names are numbers, it might not be so easy to find out.
i want to know more about the viewer using the viewer won't solve any problem if your file is too large.
can you send me an easy steps to install it The steps are explained in the README.TXT file included with the viewer download. If you don't know anything about web servers, ftp, html and similar web technology, I wouldn't recommend trying it.
[Dec 9, 2013, 6:24:04 PM]
[Link]
