Previous Thread This topic has been viewed 7152 times and has 2 replies Next Thread
live
Tutorial sloping roofs and ceilings
Re: http://www.sweethome3d.com/slopingCeilingGuide.pdf
In 2 - Sloping ceiling
Isn't it possible to select both long walls to do the operation at once?
If not a mirror options in the menu would be nice, esp. if one has to do it on more that 2 walls.
6 - Click the Create rooms button and draw a room from coordinates 5,5 to 600,495.
Use Plan → Edit room points to check that your coordinates are exact. This forms the horizontal part of the ceiling.
Can you explain it any another way please, I keep drawing it as a floor not a ceiling.
Thanks
[Nov 8, 2013, 10:10:56 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Re: Tutorial sloping roofs and ceilings
If you want to create a sloping roof, you have to draw it in two parts.
1 - the horizontal part,
2 - the sloping part.
Strictly speaking, in this example you are drawing a ceiling, not a roof.
Floors and ceilings are drawn at the same time.
Ceilings can only be seen
- from below - using the virtual visitor
- from above - using the virtual visitor and making a photo.
[Nov 8, 2013, 10:31:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
live
Well, I don't.
I put a floor in green which I do see.
I tried to put a ceiling in red, but don't see it.
[Nov 8, 2013, 11:29:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
