In 2 - Sloping ceiling Isn't it possible to select both long walls to do the operation at once? If not a mirror options in the menu would be nice, esp. if one has to do it on more that 2 walls.
6 - Click the Create rooms button and draw a room from coordinates 5,5 to 600,495. Use Plan → Edit room points to check that your coordinates are exact. This forms the horizontal part of the ceiling.
Can you explain it any another way please, I keep drawing it as a floor not a ceiling.
Re: Tutorial sloping roofs and ceilings
If you want to create a sloping roof, you have to draw it in two parts. 1 - the horizontal part, 2 - the sloping part.
Strictly speaking, in this example you are drawing a ceiling, not a roof. Floors and ceilings are drawn at the same time. Ceilings can only be seen - from below - using the virtual visitor - from above - using the virtual visitor and making a photo.
