Re: Trouble importing .dae files from Sketchup
I just tried to export to DAE from Sketchup 8.0.14345, and import the generated DAE file with no problem. Maybe, try different export options.
Emmanuel,
I also imported the staircase, and, after checking Options -> Export two sided faces in Sketchup, the staircase exports correctly, and can be imported without problems.
The strange thing is that when I check staircase in step 2 of importation, the staircase does not make a hole in the ceiling. I checked height, and made a photo in Q3 with the VV.
When I use the furniture modification wizard, the square for staircase is unchecked, even though I checked the box when importing.
The hole in the upper floor was correct on my side, but as you noticed, when the furniture import wizard is reopened afterwards to modify a staircase imported in the furniture catalog, the Staircase check box isn't selected. As that the staircase status of the imported object is correctly saved when you import it the first time or when you reselect this check box at modification time, I think it's a minor bug, and it will be fixed in the next version.
