I'm newbie. is this normal?
in the 3D view of my house some walls are transparent, is this normal? and also I can not create pictures, all somebody can tell me why and if you have any solution to this?
Re: I'm newbie. is this normal?
First time that somebody reports this strange issue... Could you check if there's any update of the driver for your graphics card? What is your system?
I had a similar thing happening (4.0, Win8): a wall becoming semi-transparent. The disturbance, _I think_, came from: - a window/door model (self made, .dae), AND / OR - walls overlapping between levels (first level going well into the second, including walls and presumably rooms with ceilings too).
the graphics card driver is the most up to date .... I have W7 32-bit, 1GB RAM and also I have the version 4.0 but with previous versions the same thing happens
Could you send me your file? Maybe you did something unexpected? By the way, the photo creation should at least work correctly at the two best quality levels.
Sorry but I couldn't reproduce your issue on my computer. In a future version (not the one released tonight), a major update of the Java3D library should appear. You'll have to check if it works better at that moment.
