Total posts in this thread: 7
Previous Thread This topic has been viewed 8969 times and has 6 replies Next Thread
oleyfe
I'm newbie. is this normal?
in the 3D view of my house some walls are transparent, is this normal? and also I can not create pictures, all somebody can tell me why and if you have any solution to this?
[May 28, 2013, 7:42:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: I'm newbie. is this normal?
First time that somebody reports this strange issue...
Could you check if there's any update of the driver for your graphics card?
What is your system?
[May 28, 2013, 8:57:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I had a similar thing happening (4.0, Win8): a wall becoming semi-transparent. The disturbance, _I think_, came from:
- a window/door model (self made, .dae), AND / OR
- walls overlapping between levels (first level going well into the second, including walls and presumably rooms with ceilings too).
Unfortunately I didn't save the file.
[May 28, 2013, 9:19:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
oleyfe
the graphics card driver is the most up to date ....
I have W7 32-bit, 1GB RAM and also I have the version 4.0 but with previous versions the same thing happens
[May 28, 2013, 10:33:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Could you send me your file? Maybe you did something unexpected?
By the way, the photo creation should at least work correctly at the two best quality levels.
[May 29, 2013, 9:32:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
oleyfe
I just sent the file ... I hope that if have slucion
[May 29, 2013, 2:17:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sorry but I couldn't reproduce your issue on my computer. sad
In a future version (not the one released tonight), a major update of the Java3D library should appear. You'll have to check if it works better at that moment.
[Jun 3, 2013, 11:03:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
