Imported Textures: Vertical Alignment with Furnature
I'm very impressed with the package, but have a minor issue: when I texture a door with a jpg of a door and scale the image to fit, it renders displaced down the object by about 25% (so the bottom of the image wraps to the top of the door. Any thoughts? Brian
Re: Imported Textures: Vertical Alignment with Furnature
Are you sure you are using the latest version 3.7? Because there was a bug about this in a previous version. For your information, the texture is applied from the bottom to the top of the object.
