Total posts in this thread: 137
Posts: 137   Pages: 14   [ Previous Page | 5 6 7 8 9 10 11 12 13 14 | Next Page ]
Previous Thread This topic has been viewed 232294 times and has 136 replies Next Thread
Re: Sweet Home 3D 4.0
Emmanuel,
Sorry for misunderstanding your improvements. I was living under the impression that one-step-ceilings were introduced for the scenarios you showed.
Would it be possible to slightly improve the "magnetism" for room points, so that it's easier to find the exact spot where room points should connect to wall points? It's easy to find the exact spot for corner points, but not so easy to find the exact spot along a split-up straight wall.
PS: Making a 6-point room in my example gives a perfect ceiling.
[Mar 3, 2013, 5:38:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sajmmon
Poland
After your feedback, I would not disable the mechanism :-) Even thougn it might not be perfect in some situations.
Have a look at an interesting example: Two rooms (almost the same), one is rotated. The same diagonals in tringulation, but different ceilings :-)
It is just a toy example, I would enable the mechanism even with this kind of inconsistencies.
[Mar 3, 2013, 6:50:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
is it possible that the last webviewer is not compatible with the lastest BETA ?
I would say no, but since you had a problem that I could reproduce, it must be true. I'll check in the coming days where it could come from.
[Mar 3, 2013, 8:59:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Ok, I fixed the bug. If you want a beta of the viewer, just tell me, I'll send it to you.
Thanks for reporting this issue. smile
[Mar 3, 2013, 9:39:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Groumphy
Belgium
Waw... Coming days are coming hours.
Yeah I'll agree for test the beta viewer ! I think you've my e-mail adress (groumphy on the domain GMail).
Or best is upload the beta version on SourceForge.
Groumphy
FR - NL - EN
Real name: Xavier Brusselaers
www.zoyo.be
www.doudoulinux.be
Pas très souvent présent, mais utilisateur :)
[Mar 4, 2013, 6:43:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
robal
Spotted a small bug (also in 3.7 if I remember correctly).
- when editing a wall color/texture, setting are not applied after clicking "OK" in "modify walls" dialog
repro:
1) set any side of the wall to any texture and close "modify walls" dialog
2) open "modify walls" dialog again, and change wall side to "color" (but without clicking the color picker button)
3) hit "OK"
4) the wall side is still textured
Cheers,
[Mar 4, 2013, 12:10:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It was just a small problem of some missing files in SweetHome3DViewer.jar file.
I've uploaded a beta version of the viewer here, to let you test.
[Mar 4, 2013, 6:14:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Groumphy
Belgium
Hello,
I've (endly) make the first test with the webviewer.
This work (for the load, the first view etc...) but I think there is a small problem with 2 thinks:
1. (most important I think) somes furnitures are in one block (no details) and colored in red ;
2. (minor) the height is not good, the code
width:"100%", height:"95%"};
is not understand by the browser...
I have one more idea for improvement: to have the level structure (tabs in SH3D) to have a first hand and not a global view.
You can view the actual problem on this link: myhome.zoyo.be.
I will check for the height and with in the Javascript and try to find a solution...
Success,
Xavier
(PS: for the test, I'm working on Ubuntu 12.04LTS, Mozilla Firefox 19.0.2, and Oracle Java 1.7.0.17 with the Firefox plugin 1.7.0.17)
Groumphy
FR - NL - EN
www.zoyo.be
www.doudoulinux.be
[Mar 10, 2013, 9:38:34 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for your tests. smile
Red blocks generally means a problem with the 3D model file. I downloaded your sh3d file and it appears that the "22" file matching some red objects is incorrect in the sh3d file. I guess you should upload again your file on the server.
Maybe it's because you included the applet script in a div tag.
Adding the levels tabs at the top of the 3D view shouldn't be too difficult. Please fill a feature request to ensure I don't forget it.
[Mar 10, 2013, 1:44:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Groumphy
Belgium
smile Re: Sweet Home 3D 4.0
Hello,
Fantastic, the first "problem" is solved.
But the second for the height isn't...
The Javascript is now out of the DIV.
I think this is because JS send info about the applet this is not à block of HTML. But today I don't have time for look about this. I will try tomorow...
For the tab in the webview I'll introduce next time ;)
Enjoy,
Xavier
Groumphy
FR - NL - EN
www.zoyo.be
www.doudoulinux.be
[Mar 10, 2013, 4:49:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
