Total posts in this thread: 52
Posts: 52   Pages: 6   [ Previous Page | 1 2 3 4 5 6 | Next Page ]
Previous Thread This topic has been viewed 145511 times and has 51 replies Next Thread
Status: Online
Re: Sweet Home 3D 3.4
Emmanuel,
I'm glad to report that the problems I reported don't exist anymore. Of course I don't understand what caused them, it's as if half of my computer was asleep.
[Oct 29, 2011, 7:30:54 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Great to read it now works for you Hans. smile
Tonight, Beta 6 fixes a few bugs found in level management, while trying to build the attached file, built from the house plan available on this site. For your information, it took me more than 6 hours to reproduce the plan and the roof of this quite complicated house with 2 levels.
Attachment House89.sh3d (249462 bytes) (Download count: 1322) (House built from plans available at http://www.construiresamaison.com/plans-maiso...cilienne-de-caractere-a89)
[Oct 30, 2011, 1:37:34 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Hello all,
If you're using Ubuntu 11.10, 64 bits, you may have difficulties using the newest beta.
Install the original Sun Java and your problem will be solved.
Here is a help page for easy installation. These are the commands I used:
sudo add-apt-repository "deb http://archive.canonical.com/ lucid partner"
sudo apt-get update
sudo apt-get install sun-java6-jre sun-java6-bin sun-java6-jdk sun-java6-plugin sun-java6-fonts
[Oct 31, 2011, 3:47:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Today's Beta 7 brought 3D view > Display all levels and 3D view > Display selected level menu items, and improved magnetism during rooms drawing (you should have much less problem to draw a simple rectangle).
I also increased a little the sensitivity of magnetism.
[Nov 2, 2011, 1:21:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pial
And now beta 8 ! ;-)
Tanks a lot for that pretty good job Emmanuel !
Pierre
[Nov 4, 2011, 8:53:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Tonight's Beta 9 adds support for levels at a negative elevation. Hope you like it. smile
As soon as you place an object, a room or a surface surrounded by walls at a level with a negative elevation, Sweet Home 3D will compute a hole that will surround the added item. Multiple underground levels containing items of different sizes are supported.
Note that the virtual visitor can't go below elevation 0, and I'm not sure I'll add that in the next update (keeping the visitor location in the home when underground isn't so easy).
[Edit 1 times, last edit by Puybaret at Nov 4, 2011, 9:43:42 PM]
[Nov 4, 2011, 9:39:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
And here's a Beta 10 because I forgot to make the required changes to the photo creation tool.
Which swimming pool will you prefer? wink
[Nov 4, 2011, 10:30:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pial
applause Re: Sweet Home 3D 3.4
I prefer the left one.
Though "underground elevation" sounds a bit strange biggrin ,
anyway it's a huge step upgrade. Great job !
How can you make it so quickly ?
Pierre
[Nov 5, 2011, 1:19:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The Beta 11 brings a few new small features and improvements:
- Added New floors thickness field in preferences pane,
- Added a button to import language libraries in preferences pane to make it easier to install SH3L files when file association doesn't work (there are now 3 SH3L available files: Traditional Chinese , Korean and Finnish),
- Added some tooltips to show the current angle on rotation axis in the 2nd step of the Import furniture wizard,
- Added a table in the Level modification dialog to help users compare the values of the edited level with the ones of other levels.
And as showed in the previous dialog, I checked that the new level feature was able to handle correctly raised floor and false ceiling. This test was made on the attached example that shows the 4 following levels when 3D view > Display selected level menu item is checked (the outer level isn't mandatory but still nice to have).
Raised floor:
Arranged space:
False ceiling:
I guess that a few ones among you are going to be happy because levels actually behave like layers when they are at the same elevation, excepted that walls are always displayed when they are at the same elevation as a level elevation, but I don't feel it's annoying for a software like Sweet Home 3D.
Like always your comments will be appreciated. smile
Attachment OfficeWithRaisedFloorAndFalseCeiling.sh3d (969045 bytes) (Download count: 2683) (Office with raised floor and false ceiling)
[Nov 7, 2011, 1:18:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Emmanuel,
I think I found a small bug in v3.4 b11 that concerns creating a room.
In the attached file the outline of a building is drawn. You will find that it is impossible to create a room by double-clicking inside this shape.
If you inspect the connection of the two wall segments marked with a red circle, you will see that this connection isn't at a 90 degree angle, but is slanted or skewed. It looks a bit like a problem you fixed earlier.
Now, if you bisect the room, you will find that you can create a room by double-clicking in the part without the red circle, but NOT in the part where the slanted connection is.
Attachment bug in Draw Room.sh3d (60201 bytes) (Download count: 505)
[Edit 1 times, last edit by hansmex at Nov 7, 2011, 4:42:11 PM]
[Nov 7, 2011, 3:49:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
