Total posts in this thread: 2
Previous Thread This topic has been viewed 1921 times and has 1 reply Next Thread
rino63
apply texture only on a piece of an object
hi, when I apply a texture on an object, for example a bed, the texture is applied on the entire bed not only a piece. better explaination: if the bed have the support of iron, the final result after the texture application should be the texture (example wood) on the structure and the support should be iron. is this result possible or I need edit the model with a modeller?
gennaro
[Apr 11, 2011, 10:04:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: apply texture only on a piece of an object
Gennaro,
You guessed right: if you want partial textures, you will have to use a modeller like Art of Illusion or Blender.
[Apr 11, 2011, 10:17:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
