(Sorry for my english,I use google translate.) I was looking for here in the forum but could not find a similar problem. I'm trying to create a video with best quality or one step below but the result video quality is bad. Only the same rendering in the 3d view+shadows is good. I thought that something went wrong on the textures that I've done. I tried different resolutions but the result was always the same. Finally I downloaded SweetHome3DExample3.sh3d has also tried, but the result was the same. Check out this sample video: SweetHome3dExample3 (Download the video to see better the problem.) Sample picture from my video: Link The whole video is very noisy. What should have to set to be good? Thanks in advance for your help.
Re: Bad video quality
I don't think it's so bad. You've got what you get for a faster computing. If you don't like it, use the best quality or a larger resolution, before reducing it with a video tool.
