Total posts in this thread: 7
Previous Thread This topic has been viewed 12674 times and has 6 replies Next Thread
geoff3
Join walls accurately 90° end to end
must have missed something, how do I join two walls at 90° without having to zoom in and ajust them. Is there a snap to the end center point? if you get my meaning?
thanks
[Jan 18, 2011, 6:31:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Join walls accurately 90° end to end
Geoff,
Read this manual, then install the AdvancedEdit plug-in.
[Jan 18, 2011, 7:21:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
geoff3
Hi Hans,
Your link just gives me a blank page
Where do I find the AdvancedEdit plugin
[Jan 18, 2011, 8:26:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Geoff,
Hover your mouse over the link, and you'll see it points to a PDF, which has been downloaded to your computer....
[Jan 18, 2011, 8:35:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
To join accurately the last wall to the first wall you draw, double click on the start point or the end point of the first wall (the wall you'll be joined to is highlighted). The start point or the end point of the wall you click on is also join to the first wall you create (even if it should be highlighted... too).
If ever you didn't succeed, delete the wrong wall and click / double-click again. I don't really understand why some users prefer a join operation than this simple operation.
By the way, the double-click that ends a group of new walls join can be done also with the keyboard by pressing twice the enter key fast (I agree this behavior isn't so handy).
[Jan 19, 2011, 8:37:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
geoff3
Thanks for all your help,
The plugin AdvancedEdit did the trick
[Jan 20, 2011, 5:50:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
peng1
Does the AdvancedEditing plugin still work? I have SH3D V3.4 installed on Windows7 and I have installed this plugin V1.2 but I do not see 'Connect Walls' under the 'Plan' menu.
[Mar 22, 2012, 12:18:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
