Total posts in this thread: 135
Posts: 135   Pages: 14   [ Previous Page | 5 6 7 8 9 10 11 12 13 14 | Next Page ]
Previous Thread This topic has been viewed 319681 times and has 134 replies Next Thread
Re: Sweet Home 3D 3.0
timcurran, maybe you have a problem with your installed version of Java.
Sweet Home 3D version 2.6 could work independently if you install it from its installer since the installer provides an internal dump of Java.
On what system do you work?
[Nov 19, 2010, 6:24:06 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
chipmaster
Puybaret, I have the same error as timcurran. After install or when try to run installed aplication I get error (see image). My friend has also the same problem.
System: Windows XP x86
Click to Details -> Exception tab
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.eteks.sweethome3d.SweetHome3DJavaWebStartBootstrap.main(Unknown Source)
at com.sun.javaws.Launcher.executeApplication(Unknown Source)
at com.sun.javaws.Launcher.executeMainClass(Unknown Source)
at com.sun.javaws.Launcher.doLaunchApp(Unknown Source)
at com.sun.javaws.Launcher.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.reflect.InvocationTargetException
at com.eteks.sweethome3d.SweetHome3DBootstrap.main(Unknown Source)
... 14 more
Caused by: java.lang.NullPointerException
at java.util.Arrays.sort(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D$AutoSaveManager.readRecoveredHomes(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D$AutoSaveManager.<init>(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.init(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.main(Unknown Source)
... 19 more
[Nov 19, 2010, 9:44:06 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thank you for this log. I fixed this bug yesterday but didn't realize it could prevent the program from running for users who never tried the beta.
I just released the beta 17 that contains the fix of this bug and other minor ones. It contains also updated Czech and Polish versions. smile
[Nov 19, 2010, 10:35:59 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
By the way, chipmaster, kudos for your desktop layout !!! laughing
[Nov 19, 2010, 10:42:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Emmanuel,
Is it correct that the beta 17 is called beta 16 in the About window?
[Nov 19, 2010, 11:18:42 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
chipmaster
Thank you Puybaret! How can I associate sh3d extension with beta on windows?
Hansmex, I see Beta 17 in the About window.
[Nov 19, 2010, 11:28:34 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Emmanuel, Chipmaster,
My version NOW says beta 17 also, but I had to delete the old icon and download it again, even though the beta 16 on starting did a big download.
[Nov 19, 2010, 11:34:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
timcurran
Yep, that was the problem. Beta 17 works for me.
Thanks, Emmanuel.
[Nov 19, 2010, 11:46:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
chipmaster
When floor(ceiling) texture/color and ground(sky) texture/color are different and door_elevation=0 (or door_elevation+door_height=wall_height) then doorstep (upper doorstep) has ground (sky) texture/color as in picture
If I increase door_elevation (or wall_height for upper doorstep) by 1 millimeter then picture is fine.
Emmanuel, maybe it's better to have 1 millimeter elevation as default for all doors/openings?
[Nov 19, 2010, 11:30:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Chipmaster,
Most probably this "problem" is not a problem.
Try this, and do it exactly in this order:
- draw you walls
- insert your doors
- draw your floor
If you do things in this order, the door makes a hole in the wall, and the floor fills half that hole.
If you first draw the floor, and then insert the doors, the floor isn't adapted to the inserted door, and the ground colour or texture is visible.
[Nov 20, 2010, 12:32:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
