Re: Sweet Home 3D 3.0
I think the problem probably comes from the left wall of the right orientation of faces sketchup. it's really strange, but I would be careful about that now.
Hans, I see you've textures of the 3 walls Q0 and Q1, I have rarely textures displayed in these two qualities, either in photo or video. Only the colors and not textures are displayed in my home at Q0 and Q1
Maybe it's Ubuntu? My version of Java? My video card or drivers? There's a lot of variables in the equation...
I searched the bug described by PtiNounours and tested by others. It's really weird and looks like that's a bug in SunFlow rendering engine. Sometimes it doesn't even try to render the texture applied to the left object. Investigating might be much more complicated than expected...
Emmanuel,
Maybe there are a few things connected here? 1 - The strange behaviour Sebastien noticed 2 - The strange behaviour I noticed with textures and transparency.
Maybe a complete "reformulation" of how textures are applied could be a solution? The fact that the tests on Sebastien's file gave different results for every run, is very strange.
I am compiling a kind of document with info on how OBJ files work, but it's very hard to find a complete and easy to understand manual, that goes into enough detail to explain what I need. Ideally I would like to construct an OBJ file for a cube that does what >>I<< want, and not what some-one else wants :-)
Sorry Hans, but reversed textures and Sebastian wrong rendering are completely unconnected. Good try, but this won't help!
About the OBJ format, create a new thread where you'll ask your questions about it. It's really not a complicated format for a programmer.
