Re: Sweet Home 3D 3.0
Good evening guys. I did several tests with my textures, and I noticed that the problem occurs at random with different textures and different files. I think, but I do not know if it is possible that the advanced rendering 1.6.1 is not fully integrated with the new version.
The parameters set in the Advanced rendering plug-in won't be copied back to Sweet Home 3D v3. Set North direction to 90°, date to 1st september, hour to 13:00, remove ceiling lights, and you will have the same results as the image you joined in your linked file.
Hope this was what you were looking for.
Good morning I tried to set adv render as you told me and this is what I see. I'm afraid of not having done everything correctly.
