Re: Some small requests?
Emmanuel,
I had to think a bit about some of your replies.
2 - Would it be possible to move the "Doors/window" checkbox from the import dialogue to the modify furniture dialogue? Maybe this is a solution to your question: - leave the check box in the import window, so that basic behaviour is the same; - add a (second, identical) check box in the advanced tab (if and when it comes); - as long as the inserted object isn't moved, its behaviour stays the same; the moment you move the object holes in walls are recalculated.
3 - The same could be done for the "Movable" check-box. I unchecked "Movable" for one of my models and played a bit with it. I can't notice any difference. What exactly does the "Movable" property do? Does it apply only to doors/windows?
4 - Transparency I noticed PNG transparency is now supported. I still have to play with this.
Didn't you know that Santa has some kids too? I checked your CV and now know that you have two kids. I certainly would hope that SH3D (soon) will generate enough spin-off to buy them all the presents you are prepared to give them.
[Oct 1, 2010, 8:56:10 AM]
[Link]
