Lock Base Plan (Flag for every Object)
It would be nice, if i can set a flag to every object, if this is also locked, when i lock base plan.
For example, i not only want to lock walls, also the kitchen is fixed in my apartment. And the bathroom. So i can lock the objects, which are not movable. Then i not need to scare to accidentally move this objects. Would also give maybe some other advantage... because you can then decide which objects are still movable after locking.
Walls, doors and windows are per default checked and all other objects are unchecked per default for this lock-flag.
