Re: Furniture Library Editor Beta released
PS noticed a very slight Arc offset when specifying SVG (but I suspect the inaccuracy may stem from the .obj file, will check) - if it remains a problem, I will report it.
Never mind. False alarm. Not the .obj file, it was a 1 in the rotation parameter (instead of large-arc-flag) that caused the confusion. Stupid, and I wasted 1/2 looking in the wrong place... :-(
Actually, SH3d deals beautifully with every SVG path I've been able to think of.
ok - overjoyed with the SVG path function in FurnitureLibraryEditor.
Please, use English in this forum (even if issued from automatic translation).
Furniture Library Editor already works under Mac OS X 10.9, but you may have to download and install Java to make it run, for example using the update available at http://support.apple.com/kb/DL1572
No problems with the Beta so far (except the lightsource properties vanished once, but have not been able to recreate ...
This happened again - light source properties had disappeared from the PluginFurnitureCatalog.properties file. Using Furniture Library Editor Version 1.12 ID, Java version 1.7.0_51.
In the sh3f file posted the modern street light no longer has light source properties, whereas the file I sent you by e-mail (created from the previous version of the .sh3f file) has light-source properties.
But exactly what I did, I cannot remember, sorry (I may have edited the model properties: height).
Pesky LightSourceProperties, another small bug reported in bugs/441: Leading zeros in colour hex triplet disappear... Probably has no practical implications (think file is read correctly), except confusing amateurs like your truly...
'special version with ID' it would be great.
I sent you a link to that special version. I'll try to add a preference in a future version to change the list of editable columns.
You shouldn't by any chance keep one of those ID specials 1.14 lying around ? (Clearly not a priority, but it was very nice.... But then, you have probably guessed that I prefer as many options as possible to avoid having to open the .properties file all the time.)
Here's the special version 1.14 of the editor with IDs. Maybe, one day I'll add the list of editable columns in editor's preferences…
[Note from developer: the special version with IDs was updated on 01/19/2017]
[Edit 1 times,
last edit by Puybaret at Jan 19, 2017, 9:26:46 AM]
