Total posts in this thread: 224
Posts: 224   Pages: 23   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 1245465 times and has 223 replies Next Thread
Re: Furniture Library Editor Beta released
The fields for SVG cutout shapes are very small. 20 characters is not very much for the customised cutouts... :-)
No problems with the Beta so far (except the lightsource properties vanished once, but have not been able to recreate so I probably entered a wrong comma or something in the .properties file).
PS: If you have link to the 'special version with ID' it would be great.
[Nov 5, 2013, 9:21:26 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You can type more than 20 characters even if the text field shows only 20 characters, but I'll try to change the layout of the dialog to show a larger text field in a coming version.
I sent you a link to that special version. I'll try to add a preference in a future version to change the list of editable columns.
[Nov 6, 2013, 2:33:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thank you, downloaded, much appreciated and enjoyed. Of course, I know I can type more than 20 characters, but my head is spinning (in elliptical arcs, they can be a pain). And seeing the entire path would make it (slightly) easier. But as I doubt adding SVG paths will be a common user pastime, I don't really think it needs to be on your priority list. Will look at more SVG this evening. Thanks for all your prompt responses to silly questions. (And thanks to hansmex for his input. Noted, will do. And .odt is just fine, not need to use .doc/docx ...:-) - will test .odt support for SVG illustrations ...)
PS noticed a very slight Arc offset when specifying SVG (but I suspect the inaccuracy may stem from the .obj file, will check) - if it remains a problem, I will report it.
[Nov 7, 2013, 5:16:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Never mind. False alarm. Not the .obj file, it was a 1 in the rotation parameter (instead of large-arc-flag) that caused the confusion. Stupid, and I wasted 1/2 looking in the wrong place... :-(
Actually, SH3d deals beautifully with every SVG path I've been able to think of.
ok - overjoyed with the SVG path function in FurnitureLibraryEditor.
[Nov 11, 2013, 5:47:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
nathalyann
Canada
smile Re: Furniture Library Editor released
Bonjour,
J'aimerais savoir si, dans un futur rapproché, l'application "Furniture Library Editor" sera disponible pour le Mac OS X 10.9 ?
Merci
Nathaly-Ann
⊰ Nathaly-Ann ⊱​
[Dec 1, 2013, 6:15:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Please, use English in this forum (even if issued from automatic translation).
Furniture Library Editor already works under Mac OS X 10.9, but you may have to download and install Java to make it run, for example using the update available at http://support.apple.com/kb/DL1572
[Dec 2, 2013, 9:57:50 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hfrmobile
Lower Austria
Downloaded the latest version (FurnitureLibraryEditor-1.13.jar). App runs. But when I open a furniture file the List keeps empty.
So I renamed exterior-door-03.zip to exterior-door-03.sh3f (since it is simply a zip file containing model data files) voilà ...
But I have no idea how to draw door opening/angle (for 2D plan).
[Feb 17, 2014, 10:12:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hfrmobile
Lower Austria
Door swing in plan ...
[Feb 17, 2014, 10:13:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
No problems with the Beta so far (except the lightsource properties vanished once, but have not been able to recreate ...
This happened again - light source properties had disappeared from the PluginFurnitureCatalog.properties file. Using Furniture Library Editor Version 1.12 ID, Java version 1.7.0_51.
In the sh3f file posted the modern street light no longer has light source properties, whereas the file I sent you by e-mail (created from the previous version of the .sh3f file) has light-source properties.
But exactly what I did, I cannot remember, sorry (I may have edited the model properties: height).
[Feb 25, 2014, 8:57:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Pesky LightSourceProperties, another small bug reported in bugs/441: Leading zeros in colour hex triplet disappear... Probably has no practical implications (think file is read correctly), except confusing amateurs like your truly... confused
[Feb 28, 2014, 4:29:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
