Total posts in this thread: 169
Posts: 169   Pages: 17   [ Previous Page | 8 9 10 11 12 13 14 15 16 17 ]
Previous Thread This topic has been viewed 782296 times and has 168 replies Next Thread
There's no separated version history for the Furniture Library Editor. The version 1.28 only brought some icon changes.
[Aug 31, 2021, 2:27:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
For building the FurnitureLibraryEditor-version.jar file with the furnitureLibraryEditorJarExecutable target, the Color button does not open any panel and displays this message in the command prompt:
Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: input == null!
at javax.imageio.ImageIO.read(Unknown Source)
at com.eteks.sweethome3d.swing.SwingTools.createCustomCursor(Unknown Source)
at com.eteks.sweethome3d.swing.ColorButton$RecentColorsPanel.<init>(Unknown Source)
at com.eteks.sweethome3d.swing.ColorButton.createColorChooser(Unknown Source)
at com.eteks.sweethome3d.swing.ColorButton.access$300(Unknown Source)
at com.eteks.sweethome3d.swing.ColorButton$2.actionPerformed(Unknown Source)
at com.eteks.furniturelibraryeditor.swing.ModelLightSourcesComponent$ModelLightSourcesPanel.displayView(Unknown Source)
at com.eteks.furniturelibraryeditor.swing.ModelLightSourcesComponent$1.actionPerformed(Unknown Source)
at com.eteks.sweethome3d.swing.SwingTools.showOptionDialog(Unknown Source)
at com.eteks.sweethome3d.swing.SwingTools.showConfirmDialog(Unknown Source)
at com.eteks.furniturelibraryeditor.swing.FurniturePanel.displayView(Unknown Source)
at com.eteks.furniturelibraryeditor.viewcontroller.FurnitureController.displayView(Unknown Source)
at com.eteks.furniturelibraryeditor.viewcontroller.FurnitureLibraryController.modifySelectedFurniture(U
nknown Source)
at com.eteks.furniturelibraryeditor.swing.FurnitureLibraryTable$3.mouseClicked(Unknown Source)
In Eclipse, the Color button opens the color modification panel.
EnkoNyito
[Edit 1 times, last edit by enkonyito at Sep 3, 2021, 4:49:58 PM]
[Sep 2, 2021, 3:12:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Many files of Sweet Home 3D are excluded from the JAR executable file of the Furniture Library Editor, to build a JAR file as small as possible.
If you change the features of the editor, you'll have to check which files you should not exclude anymore. In your case, I guess you need the pipette cursor icons found in com/eteks/sweethome3d/swing/resources/cursors folder.
[Sep 4, 2021, 9:32:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Indeed, the problem is solved by including the pipette cursor icons.
Here is the derived version that allows to create lights and modify their sources.
FurnitureLibraryEditor-1.28_derived.jar
FurnitureLibraryEditor-1.28-src_derived.zip
Note: As it is not possible to attach the files because apparently their sizes exceed the maximum allowed, I put links to SourceForge.
EnkoNyito
[Edit 2 times, last edit by enkonyito at Sep 5, 2021, 10:53:35 PM]
[Sep 5, 2021, 10:17:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
harbinger
US
The derived version works well, but i'm leery of those icons. Yuk!
Would be great if the light editor would draw where the light source is in relation to the model, using the XYZ we enter. I love the fact that i can adjust the color right there!
[Sep 20, 2021, 2:39:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@harbinger
The standard version of the FurnitureLibraryEditor-1.28 tool uses the new icons of Sweet Home 3D 6.6 .
It would be interesting but this problem does not yet have a solution.
EnkoNyito
[Sep 20, 2021, 5:35:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
davidzhghenti
Georgia
Good day all..
I download this program... In YouTube I saw Up panel is "Tools". near the File, EDIT, Plan, Help. in this How I add "TOOL"?
thanks,,,
[Oct 23, 2021, 8:10:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
I don’t know what you saw but the Furniture Library Editor is a separated application as explained in the first message of this thread.
[Oct 23, 2021, 10:16:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
FurnitureLibraryEditor-1.28.1_derived
  • added light sources 3D preview (transparent light, opaque source)
executable jar
source code
EnkoNyito
[Oct 27, 2021, 11:11:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2021 eTeks - All rights reserved
