Total posts in this thread: 4
Previous Thread This topic has been viewed 4346 times and has 3 replies Next Thread
riesart
inserting a window breaks custom texture
Hi there,
Whenever I insert a window in one of the walls, it breaks up the texture of that wall. The wall has a custom texture of an image. The window breaks up the image.
How can I solve this?
Thank in advance,
Richard
[Feb 19, 2010, 5:10:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: inserting a window breaks custom texture
Richard:
What happens is this: every time you insert an object in a wall, SH3D (internally) begins a new wall segment. That means that it also re-starts the texture. It is this effect that you have noticed.
If it is important that the texture is seamless, you can make a tailor-made texture for that wall. See this manual .
Another solution would be to insert the window at the exact start of a new texture. Maybe using a close-up view of the textured wall will allow you to place the window (or door) on the exact right place.
[Feb 19, 2010, 6:27:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
riesart
Thanks, Hans, Ik will see if I can sove it.
Richard
[Feb 19, 2010, 6:29:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Richard, I fixed this problem in Sweet Home 3D version 2.3 Beta. Please try it.
Note that texture still breaks at each wall. So if you divide a wall in two parts, the texture will restart on the second wall.
[Feb 19, 2010, 9:46:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
