Re: Sweet Home 3D 2.3
Emmanuel:
After a quirky start with Windows Vista (maybe you have seen my deleted post) everything in v2.3b15 seems to work fine on both my computers.
I'm busy updating the English manual and hope to provide a "serious" first draugth (a beta version) pretty soon.
One suggestion for the menu structure: move Plan -> Export to SVG format to 3D view -> Export to SVG format. It seems more logical to have them together. Or else, maybe, you could create a new menu item called Tools or Extra (as in Windows) where you put all the extra tools together.
[Edit 1 times,
last edit by hansmex at Feb 24, 2010, 2:30:13 PM]
I found a bug (I think). v2.3b15 When I tried the create photo, the quick one and the one after that worked but the Best and the next to best did not. It (the rendering area) was just black.
The.camera was probably in a wall, and with the two best quality renderers, this will make a black image.
Hello Puybaret,
here is my Stactrace:
Java Web Start 1.6.0_15 Verwendung der JRE-Version 1.6.0_15-b03 Java HotSpot(TM) Client VM
---------------------------------------------------- Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: adding a container to a container on a different GraphicsDevice at java.awt.Component.checkGD(Component.java:1099) at java.awt.Container.checkGD(Container.java:1105) at java.awt.Container.checkGD(Container.java:1105) at java.awt.Container.addImpl(Container.java:1041) at javax.swing.JLayeredPane.addImpl(JLayeredPane.java:212) at java.awt.Container.add(Container.java:927) at javax.swing.JRootPane.setContentPane(JRootPane.java:608) at javax.swing.JDialog.setContentPane(JDialog.java:997) at com.eteks.sweethome3d.swing.HomePane.detachView(Unknown Source) at com.eteks.sweethome3d.swing.HomePane.detachView(Unknown Source) at com.eteks.sweethome3d.viewcontroller.HomeController.detachView(Unknown Source) at com.eteks.sweethome3d.swing.HomePane$1.actionPerformed(Unknown Source) at com.eteks.sweethome3d.swing.ResourceAction$AbstractDecoratedAction.actionPerformed(Unknown Source) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242) at javax.swing.AbstractButton.doClick(AbstractButton.java:357) at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1225) at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:1266) at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:272) at java.awt.Component.processMouseEvent(Component.java:6263) at javax.swing.JComponent.processMouseEvent(JComponent.java:3267) at java.awt.Component.processEvent(Component.java:6028) at java.awt.Container.processEvent(Container.java:2041) at java.awt.Component.dispatchEventImpl(Component.java:4630) at java.awt.Container.dispatchEventImpl(Container.java:2099) at java.awt.Component.dispatchEvent(Component.java:4460) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168) at java.awt.Container.dispatchEventImpl(Container.java:2085) at java.awt.Component.dispatchEvent(Component.java:4460) at java.awt.EventQueue.dispatchEvent(EventQueue.java:599) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161) at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Thank you brill for this stack trace. It should help me to fix the bug. Do you have two screens?
