Re: Sweet Home 3D 2.3
I found the bug about the grouping info. In fact the grouping info is lost in memory just after you save your home. So if you save twice a home with a group, the group info will be lost also in the file. Sorry for this problem, I will be fixed in the next beta version.
Emmanuel:
Thanks for your dedication and meticulous bug hunting. Please, don't say sorry for bugs in the program, I guess it's inevitable. What counts, is the speed with which they are solved.
Thanks again!!
Here's version 2.3 Beta 9 with the ability to create Quicktime (.mov) videos from a path of camera locations recorded by the user.
I hope you'll appreciate this feature I previously announced in Sweet Home 3D blog, and won't find it to complicate to use. I tried to make it simple enough, but it will probably take you a little time to master it. Don't hesitate to make suggestions.
I'm looking forward discovering your nice videos.
Note: Quicktime format was chosen mainly because the free JMF library I chose is able to generate only AVI or MOV videos, and MOV videos seem to support more sizes and frame rates.
Unfortunately, every time I click the Create button the program crashes. I have searched for an error log but cannot find it.
If it crashes there must be a hs_err....log file somewhere, but I'm not sure it will help. Does it crash as soon as you click on the Create button? Does it crash as soon on any quality level (1/2 and 3/4 levels doesn't work the same)?
Emmanuel:
First, I tried the beta-9 on my Windows Vista laptop and it worked fine when I clicked the Play button. It also works when clicking the Create button and starts making several thousand images. This is a (more or less) slow process: my laptop is now busy making its first movie and rendering image 500 of 3500 or so. I guess that will take another half hour.
I managed to find 3 crash reports which I sent to your email.
When clicking the Play button on my Ubuntu PC, the virtual man starts walking around my model. But, when I click Create and use quality level 1 or 2, I can only see the number of images that should be created before the program crashes. Following your question, I tried quality setting 3 and 4. See the results below.
The following pictures and movies are from my Ubuntu PC.
This is a screen shot from the standard render in SH3D.
This is a screen shot of the movie in quality setting 3. The quality is a bit disappointing.
This is a screen shot of the movie in quality setting 4. The quality is a bit disappointing.
And finally a screen shot of the movie in quality setting 1 rendered on my Windows Vista laptop, played on my Ubuntu PC.
[Edit 3 times,
last edit by hansmex at Feb 19, 2010, 6:19:00 PM]
I think outside views in quality 3 and 4 depends on the sky texture. Maybe the images I provided are too blue. I'm curious too see how horizontal maps provided at http://blender-archi.tuxfamily.org/Textures#Horizontal_maps would render.
One last thing, nobody ever complained about the color used to draw the top of walls in the 3D view. I'm opened to change it if you give me good ideas.
Today, I decided to try to apply texture on furniture, and guess what? I felt it worked well enough to release this new feature in version 2.3 Beta 12.
From the image below, you'll see that the texture image isn't mapped on the left and the right sides of an object as expected, but I think it's not possible to do better with no additional parameter which would be probably to complicated for many users.
Argentina
Bonjour Emanuel Nice!! Is this Beta using DirectX or OpenGL for J3D?
Well, guess what; it works on my notebook (that's a huge improvement!!). However: -The navigation arrows look scrambled (maybe due to the bl##dy poor OGL support for my card) -No Top view for furniture on the plan (idem) (I guess when I use DirectX it looks fine anyway)
Nice the searchable list, but it could be better to include a switch between folders and list in the furniture catalog context menu (like switch from Aereal View to Virtual Visit in the 3D view)
Everything else is perfect.
Greatest new features (OMHO): -Ctrl click to zoom Plan -Change the visitor's height -Group/Ungroup -Create Videos
