Xtian74
Re: Insertion de dalles entre 2 niveaux ?
Bonsoir Emmanuel, Merci pour le pointeur vers cette page. La phrase clé est"The elevation of a level is the height of its floor on which furniture is placed. But the bottom of the walls of a level is at the elevation of that level minus its floor thickness to join nicely with walls at lower levels when you use default values. The elevation of a level may also be negative to design a basement or foundations." J'ai pu me debrouiller !
[Nov 5, 2022, 5:55:57 PM]
[Link]
