AU
Avoiding Unintentional Changes to Selected Objects
i have found when selecting an object, intentionally or accidentally, almost always, the slightest mouse tremor makes an unintentional Move to the object
in fact, i have found it very difficult to select an object, WITHOUT accidentally moving the object
which is really frustrating in two ways - 1. if i don't notice, then my painstaking work setting position and size is screwed; 2. if i DO notice, i have to waste a lot of time to set it make to the position and size it was (unless Undo works - which i am constantly having to do most times i try to simply just Select an object)
is there some setting to fix this, is there some trick to it, is there some mouse setting that would help?
