Total posts in this thread: 6
Previous Thread This topic has been viewed 891 times and has 5 replies Next Thread
decard
AU
Missing Functions: No Sizing Fields for Rooms
there appear to be NO sizing fields for ROOMS, unlike WALLS!
you are forced to drag the dimensions manually and try to get right
this seems completely crazy.
[Aug 16, 2022, 9:51:59 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Missing Functions: No Sizing Fields for Rooms
If you want to enter the exact length of each side, press <enter> then type the length of each side. Nothing crazy, just read the included help!
[Aug 16, 2022, 6:37:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
decard
AU
[moderated]
[Edit 2 times, last edit by Puybaret at Aug 18, 2022, 11:51:06 AM]
[Aug 18, 2022, 10:47:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
decard
AU
that suggestion simply doesn't seem to work after many attempts.
and that ignoores the fact that the simple, easy, and obvious, fix is to have size fields
[Aug 18, 2022, 6:31:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It's available only at Room creation time and when the plan has the focus (bordered by a blue line).
simple, easy
Don't think everything is easy and necessary because you want it!
You could also try AdvancedEditing plug-in.
[Aug 18, 2022, 7:04:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
decard
AU
again, so helpful.
[Aug 20, 2022, 2:22:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
