Posts: 108   Pages: 11   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 75884 times and has 107 replies Next Thread
Johannes_Angello
Deutschland
Re: Weird 3D Artifacts
I have the same issue with:
GPU - AMD Radeon RX 6600 XT - Primär/Diskret
VRAM - 8176 MB - GDDR6 2000 MHz
Treiberversion - 22.20.19.11-220915a-383673E-AMD-Software-Adrenalin-Edition
AMD Windows-Treiberversion - 31.0.12019.11001
Direct3D-API-Version - 12.1
Vulkan™ API Version - 1.3.217
OpenCL™ API Version - 2.0
OpenGL® API Version - 4.6
Direct3D® Driver Version - 9.14.10.01523
Vulkan™ Driver Version - 2.0.233
OpenCL® Driver Version - 31.0.12019.11001
OpenGL® Driver Version - 22.09.1462311
2D-Treiberversion - 8.1.1.1634
2D-Treiberpfad - /REGISTRY/MACHINE/SYSTEM/CurrentControlSet/Control/Class/{4d36e968-e325-11ce-bfc1-08002be10318}/0001
UI-Version - 2022.0915.1840.1936
AMD Audio-Treiberversion - 10.0.1.24
Treiberanbieter - Advanced Micro Devices, Inc.
Windows Edition - Windows 10 Core (64 bit)
Windows-Version - 21H2
Im trying to escalte this topic via AMD.
Does anyone have got a solution yet?
[Sep 25, 2022, 11:46:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
cyphorage
Just confirming that this is still an issue with latest Adrenaline driver (22.9.1) released yesterday (2022-09-21)
https://www.amd.com/en/support/kb/release-notes/rn-rad-win-22-9-1
Does anyone know the exact crux of the issue so that we can report it directly to AMD?
I reported this as a bug to AMD directly with their bug reporting tool. Instructions for doing so can be found here: https://www.amd.com/en/support/kb/faq/amdbrt. I have linked to this thread for further reference along with uploading some relevant screenshots. Hopefully that helps them
[Sep 25, 2022, 2:55:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
cyphorage
Just updated to 22.9.2 (released today, 2022-09-27) and the issue persists. I will be reporting this bug to AMD again.
[Sep 27, 2022, 10:24:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
quallemalle
I recently switched my GPU from Nvidia to AMD and also can confirm this bug with 22.10.1 driver :/ Will create a bug report
[Oct 21, 2022, 2:31:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
coldcomfort
Just happened to me too. I had no issues the other day and made no driver or windows update since (did install a new firewall). Only installed a few sweethome3d plugins the last time, but all worked just fine then.
The 3d view window is grey now when opening the program, with no model. Then loading a model gives those artifacts above, in both the 3d view and planview (objects are all black). And everything is a mess. Tried reinstalling and got the same issues.
AMD Radeon Vega 8 integrated graphics
[Edit 6 times, last edit by coldcomfort at Oct 24, 2022, 5:06:15 PM]
[Oct 24, 2022, 4:19:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Could some of you try Sweet Home 3D executable jar with a recent version of Java 17:
- download Java 17 and install it
- download Sweet Home 3D executable jar
- open a cmd window and run the command:
java --add-opens=java.desktop/sun.awt=ALL-UNNAMED --add-opens=java.desktop/com.apple.eio=ALL-UNNAMED --add-opens=java.desktop/com.apple.eawt=ALL-UNNAMED -jar path\to\SweetHome3D-7.0.2.jar
(to get SweetHome3D-7.0.2.jar file path easily, drag-and-drop the file in the cmd window).
I wonder if it would run better, it could also worth to try the 32 bit version of Sweet Home 3D.
[Edit 1 times, last edit by Puybaret at Oct 24, 2022, 6:28:28 PM]
[Oct 24, 2022, 6:24:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
coldcomfort
I fixed it by reinstalling my radeon software, with a factory reset. Downgrading to the 22.5.1 version.
[Edit 1 times, last edit by coldcomfort at Oct 25, 2022, 11:06:00 AM]
[Oct 25, 2022, 11:05:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
quallemalle
Tried out running the jar with Java 17 as you mentioned but it did not fix the issue :/ (AMD Driver 22.10.3)
[Oct 28, 2022, 3:55:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GeoYla
Just ran into this problem as well... so I guess we have to wait for AMD to fix it? Shame.
[Oct 31, 2022, 7:44:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You’re not obliged to wait for AMD good will, just downgrade to version Adrenaline 22.5.1.
[Oct 31, 2022, 10:38:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
