Previous Thread This topic has been viewed 2289 times and has 2 replies Next Thread
T_R
currently ;China
U-shape Roof top tiles
Hello all,
I look for kind of U-shaped roof top tiles to create ... a roof. :)
dont want use a texture- just dident look well on roofs.
this tile should look like on spanish roofe, as a sample.
Thanks
Laptop : EEEPC 1201N
250GB, 2 GB Ram, Broken Display, SH3D 6.2
Behind Chines "Firewall"- NO Google Servive working at all.
Never give Up!
[Aug 4, 2022, 7:20:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Re: U-shape Roof top tiles
You can create a single tile with a box and a cylinder. Move the cylinder halfway into the box and you have your U-shape. What I often do is create such a thing 10 or 100 times as big as the end result should be. That makes it easier to move the parts in the correct position. Export it and when you import it adjust the size to the required size (/10 or /100).
You can use a box as the base of your roof and then put on the tiles. The box makes is easier to determine the correct angle needed for the tiles.
That said, you really want to create a roof by 'laying' single tiles to get a full roof? That's a lot of tiles and a lot of work. On the other hand, the end result should look awesome with real height differences on the roof and not an illusion through a texture. I would really like to see the result.
[Aug 5, 2022, 8:50:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
T_R
currently ;China
@Keet,
Yes i like to make the tiles "hand-by-hand", because this project is documentary as a part of my hobby. i already created a lot things " by hand" . is there a changes you can send me your solution as a picture by email? thanks
Never give Up!
[Aug 7, 2022, 4:27:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
