Total posts in this thread: 5
Previous Thread This topic has been viewed 3544 times and has 4 replies Next Thread
Ditrovic
Sudden problem using SH3D on chromebook Linux - no menu
Hello
My students use SH3D on a chromebook. I installed the Linux-environment and for more than a year, everything worked fine. It had some minor issues, but nothing problematic.
Since a month, SH3D starts but the entire menu is empty and it can't be clicked on. The field with the 3D-rendering is completely back and also empty.
2 months ago, everything worked perfectly.
I tried to install it on a new chromebook, same problem.
Anyone with the same problem?
Is there a workaround?
Thank you
Dieter.
[Jun 21, 2022, 12:45:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Sudden problem using SH3D on chromebook Linux - no menu
There have been no new release of Sweet Home 3D for months, so it might be an issue in the operating system or in the repository where you downloaded it from. Where did you get it?
Note that except for the Online version, I even didn't think that Sweet Home 3D could work on a chromebook!
[Jun 21, 2022, 2:19:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Ditrovic
Thanks for your fast reply.
I only used:
sudo apt-get update
sudo apt install sweethome3d
There's a Linux-option in the chromebooks that you can enable.
It's very basic, but it works.
Unfortunately it's very difficult to find any information online of chromebooks with linux. I'm curious how long it will take before Google abandons the project.
[Jun 21, 2022, 2:42:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Would it be possible that you try the version available at Download page?
[Jun 22, 2022, 6:31:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Ditrovic
Thanks for the reply's.
I solved it by installing Sweet Home 3D this way:
sudo apt update
sudo apt install flatpak
flatpak install https://dl.flathub.org/repo/appstream/com.sweethome3d.Sweethome3d.flatpakref --user
[Mar 24, 2023, 9:55:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
