Total posts in this thread: 7
Previous Thread This topic has been viewed 1159 times and has 6 replies Next Thread
sruuk
copy level and seperate
Hi.
I have been using sh3d for a few months and am extremely happy with it, thanks to all who make this happen!
I have multiple levels and 1 level I want to have a few variants, I can easily add another level at same elevation but what I want to achieve is that the 2 should not be connected, if I delete a wall in 1 it should not effect the other, is there a way to do this?
Many thanks.
[May 18, 2022, 4:22:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: copy level and seperate
Welcome on the forum,
You could reorganize your design with 3 levels at the same elevation: one would contain walls, the other two levels the two variants with furniture that you would make unviewable alternatively.
[May 19, 2022, 9:13:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sruuk
thanks for your response, it is walls that I want to change between the variants. I am very reluctant to save as a separate file as then I cannot track the changes on the other levels, I already have 7 different files and each time I make a change which applies to all I need to make the same change in 7 files.. it would would be amazing if I could have it all in 1 file.
If its not possible at the moment how likely is it that "untracked" levels might be added as a feature?
Many thanks
[May 19, 2022, 11:13:14 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Replacing "walls" with "furniture" in Puybaret answer:
You could reorganize your design with 3 levels at the same elevation: one would contain furniture, the other two levels the two variants with walls that you would make unviewable alternatively.
[May 19, 2022, 12:19:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sruuk
i see so i should make walls out of furniture?
[May 19, 2022, 1:01:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
otadmin
Just tried it and you can build walls on each level at the same elevation separately. Just make the other levels invisible. The changes you make on the visible layer will not influence the invisible ones.
[May 19, 2022, 1:08:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sruuk
I will try that, many thanks to you all.
[May 19, 2022, 8:46:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
