wdh
Re: SweetHome3D crashing on opening my home
Apparently I did not install it yet. I was using the Java WebStart version.
The installer version doesn't run here at all. This is probably due to Ubuntu lacking 3D support for my GPU. Or actually, due to ATI for dropping support for the card in the fglrx driver.
I guess there's not much left to try?
For information, the error message when running the installer version follows. After this, I get a message box stating that SweetHome3D is exiting because of a 3D error.
wouter@nootboek:/data/home/wouter/temp/SweetHome3D-2.1$ ./SweetHome3D Java 3D ERROR : GLX extension is not supported GLX version 1.3 or higher is required javax.media.j3d.IllegalRenderingStateException: Can't create graphics environment for Canvas 3D at com.eteks.sweethome3d.j3d.Component3DManager.getCanvas3D(Unknown Source) at com.eteks.sweethome3d.j3d.Component3DManager.getOnscreenCanvas3D(Unknown Source) at com.eteks.sweethome3d.swing.HomeComponent3D.<init>(Unknown Source) at com.eteks.sweethome3d.swing.HomeComponent3D.<init>(Unknown Source) at com.eteks.sweethome3d.swing.SwingViewFactory.createView3D(Unknown Source) at com.eteks.sweethome3d.viewcontroller.HomeController3D.getView(Unknown Source) at com.eteks.sweethome3d.swing.HomePane.createPlanView3DPane(Unknown Source) at com.eteks.sweethome3d.swing.HomePane.createMainPane(Unknown Source) at com.eteks.sweethome3d.swing.HomePane.<init>(Unknown Source) at com.eteks.sweethome3d.swing.SwingViewFactory.createHomeView(Unknown Source) at com.eteks.sweethome3d.viewcontroller.HomeController.getView(Unknown Source) at com.eteks.sweethome3d.HomeFramePane.<init>(Unknown Source) at com.eteks.sweethome3d.HomeFrameController.getView(Unknown Source) at com.eteks.sweethome3d.HomeFrameController.displayView(Unknown Source) at com.eteks.sweethome3d.SweetHome3D$5.collectionChanged(Unknown Source) at com.eteks.sweethome3d.model.CollectionChangeSupport.fireCollectionChanged(Unknown Source) at com.eteks.sweethome3d.model.CollectionChangeSupport.fireCollectionChanged(Unknown Source) at com.eteks.sweethome3d.model.HomeApplication.addHome(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.runApplication(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.access$100(Unknown Source) at com.eteks.sweethome3d.SweetHome3D$1.run(Unknown Source) at java.awt.event.InvocationEvent.dispatch(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source)
[Nov 17, 2009, 7:27:57 PM]
[Link]
