Total posts in this thread: 7
Previous Thread This topic has been viewed 4931 times and has 6 replies Next Thread
Sand0411
Disable Autoupdate
We use the silent installation. Is it possible to deactivate the autoupdate option with a command within the silent installation, without doing it manually?
[Mar 8, 2022, 8:39:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Disable Autoupdate
If by autoupdate option, you mean the option in preferences that allows to check if some updates are available (it just checks and won't update the program), it's not possible without changing and recompiling the program.
Why not using the last version so this dialog box won't appear?
[Mar 8, 2022, 2:19:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sand0411
Thanks for the information. We use a reborn-solution, so that the uses are not able to make any changes at the system, including the updates. So the dialog box only disturb.
[Mar 9, 2022, 6:21:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I'll see if I can add this feature in a coming version.
[Mar 9, 2022, 2:24:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sand0411
That would be great, thanks.
[Mar 10, 2022, 5:32:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Please try the new /checkUpdatesDisabled argument I added to Windows installer in version 7.0.
[Jul 13, 2022, 10:13:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sand0411
It works perfect - thanks!
[Nov 7, 2022, 10:36:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
