Romania
Re: Plugins manager
Thanks YGYL! You've made a hard work to support this community. I'm not joking wile, in the past, I've try to make translation and I knew what it's mean. It's not an easy task IF you want to do a good job. I will add You's translations to all my new versions of my plugins. Thanks!!!
---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law (Greer's Third Law) When all else fails, read the instructions.Murphy's Law
Romania
Re: Plugins manager
@Daniels118 What if You update version including here?(now v 1.5)???
Italy
Re: Plugins manager
Hi, I'm happy to announce that the Plugin manager official repo now supports plugins within zip archives, so these plugins will show up in the Plugin manager without the need to update.
Re: Plugins manager
You should change the confirmation window that a plugin is updated to a always on top modal window. Currently if you updated a plugin and clicked next to the window the "plugin ready ..." window is hidden behind the manager window. Now it seems like the program hangs so you have to move the manager window to see the OK window.
Re: Plugins manager
Ah, if I had known you installed Plugins Manager 1.0 I wouldn't have send you to this thread. That is an old version of the Plugins Manager. Get the latest version here .
As on this forum on sourceforge posts go from first to last so the post with the last version is somewhere at the end, in this case on page 2. The link is for a direct download of version 1.5.2. That should work a lot better ;)
Re: Plugins manager
@Daniele You might want to check the "Replace furniture" plugin in the plugin list since it doesn't seem to work anymore and blocks Sweet Home 3D from starting beyond the splash screen. At least my 7.2. on Linux doesn't work with it. Maybe remove it from the list if it also doesn't work on other systems so other users will not run into the same problem.
