Total posts in this thread: 4
Previous Thread This topic has been viewed 938 times and has 3 replies Next Thread
titust11
Canada
How to adjust the transparency of one or several walls only, NOT ALL
Is there a way to adjust wall transparency per wall and not only globally?
[Jan 11, 2022, 5:43:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Re: How to adjust the transparency of one or several walls only, NOT ALL
Can you explain in detail the purpose of the request?
If you want a wall made of transparent glass there is a special window made of glass blocks, or you can create your own with 3D modelling software like Blender.
If instead you want to hide a wall to better view inside a room you have several options:
  • change the wall height to a lower value;
  • use transparent boxes to cut out parts of the wall;
  • use Pan3dView plugin which has a feature to automatically hide the walls that obstructs the view.
[Jan 11, 2022, 8:25:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
titust11
Canada
I created a level containing only the gravel layer that's all around the house and on a slope. I made that with walls instead of boxes and triangles. [moderated]
[Note from moderator: don't hope more help if you start to be vulgar]
[Edit 2 times, last edit by Puybaret at Jan 12, 2022, 4:56:01 PM]
[Jan 12, 2022, 12:28:56 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
This article may interest you.
[Edit 1 times, last edit by Puybaret at Jan 12, 2022, 4:56:18 PM]
[Jan 12, 2022, 3:58:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
