United Kingdom
How to select a group to move
How do I select the whole of a small grouped object so I can move it? If I select the group in the object list, that doesnt select it on the plan, but as soon as I try to select on the plan it only highlights the smallest component of the group.
Re: How to select a group to move
This should or maybe the zoom factor in your plan is so large that you don't see the selection border.
Click first in a empty space of the plan or on another object, then click on the group again.
What davequ probably means is: - if you select a model/group in the 2D pane, you can move it with the cursor keys. - if you select a model/group in the furniture list, the model/group is highlighted in the 2D pane, but cannot be moved with the cursor keys. - it would be nice to be able to move the model/group directly after clicking in the furniture list, without having to "confirm your selection" by clicking on it again in the 2D pane.
You can already do that: press Tab once or twice (if your plan has levels) to transfer focus to the plan, so pressing arrow keys will be directed to the plan.
