Total posts in this thread: 9
Previous Thread This topic has been viewed 2230 times and has 8 replies Next Thread
YGYL
shock Sweet Home 3D 6.5A bug was found in Sweet Home 3D
In SweetHome3D.jar inside com\eteks\sweethome3d\model\LengthUnit_zh_CN.properties
Inside should be changed to
centimerUnit=\u5398\u7c73
The original has a few extra letters in front of it
This can lead to errors in area calculation units
Please fix as soon as possible
The full content of the correct LengthUnit_zh_CN.properties
# LengthUnit_zh_CN.properties 16 Mar. 2009
# Translated to Chinese (Simplified) by Zhao Si-cong
# Sweet Home 3D, Copyright (c) 2008 Emmanuel PUYBARET / eTeks <info@eteks.com>
# This program is free software; you can redistribute it and/or modify it under
# the terms of the GNU General Public License as published by the Free Software
# Foundation; either version 2 of the License, or (at your option) any later
# version.
# This program is distributed in the hope that it will be useful, but WITHOUT
# ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
# FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
# details.
# You should have received a copy of the GNU General Public License along with
# this program; if not, write to the Free Software Foundation, Inc., 59 Temple
# Place, Suite 330, Boston, MA 02111-1307 USA
# Units (\u00b2 is the symbol for supercript 2)
inchUnit=\u82f1\u5bf8
millimeterUnit=\u6beb\u7c73
meterUnit=\u7c73
squareMeterUnit=m\u00b2
squareFootUnit=\u5e73\u65b9\u82f1\u5c3a
[Dec 4, 2021, 6:05:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Sweet Home 3D 6.5A bug was found in Sweet Home 3D
I checked, even double checked with a binary editor and don’t see any hidden character in the centimeterUnit line of LengthUnit_zh_CN.properties.
How do you see the bug that you encountered?
[Edit 1 times, last edit by Puybaret at Dec 5, 2021, 8:08:47 PM]
[Dec 4, 2021, 6:39:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
centimerUnit
centimeterUnit
These 2 words are not the same
[Dec 5, 2021, 5:45:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
It seems that the same mistake occurs in Russian
[Dec 5, 2021, 5:47:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
@YGYL You've right. That is what I've discover earlier.
BUT
@Emmanuel Is something strange:
centimeterUnit must be the correct.
In this case CN & RU don't work as aspect but TW which have centimerUnit = work.
If change CN & RU to incorrect form = work.
I suspect it is also a misspelling in other place of translations.
How to verify and reproduce:
1. Open a home with rooms;
2. Set preferences to English & centimeter;
3. Menu->Tools->RoomsInfo ==> in table are m₂ => OK
4. Set preferences to Chinese or Russian and repeat step 3 ==> ft₂ => Not OK.
If change centimerUnit with centimerUnit in CN & RU files will work but it has no logic (at least for me).
[Dec 5, 2021, 6:38:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I fixed this error in LengthUnit_zh_TW.properties, but it was the only wrong file.
In all cases, surface texts shouldn't be based on centimerUnit property but on squareMeterUnit or squareFootUnit properties according to the current unit set in preferences, and to avoid wondering how to format surface texts, programs should use getAreaFormatWithUnit in LengthUnit class, like in the PlanComponent class.
Dorin, did you use the same way?
[Dec 5, 2021, 8:29:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
@Emmanuel
I don't remember what I've use (it was long time ago) but probably I don't use this way.
At the moment I steel fight with roofs.
After I finish somehow this, I'll reanalyze RoomsInfo plugin and I'll tray to improve it.
Thanks for the clue!! I really need it.
[Dec 6, 2021, 10:37:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I just checked the source code of the TotalResult class you programmed, and you formatted surface texts another way in UpdateCalc method.
As you compute the text of the surface unit unitSurf from the name of the current length unit, this can lead to errors for languages where this name is localized (like Chinese or Russian).
A quick fix could consist of testing the current unit and not its name. Therefore, the line:
if (unitName.equalsIgnoreCase("mm") || unitName.equalsIgnoreCase("cm") || unitName.equalsIgnoreCase("m")) {
should rather be:
if (preferences.getLengthUnit() == LengthUnit.MILLIMETER || preferences.getLengthUnit() == LengthUnit.CENTIMETER || preferences.getLengthUnit() == LengthUnit.METER) {
Good luck for the roofs!
[Dec 6, 2021, 11:33:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Many thanks Emmanuel!!
Today I'll take a break from roof and I'll try to fix RoomsInfo.
If succeed I'll publish a fixed version.
Thanks again, without You, I have to spend mounts to find the bug (if I find)
[Dec 6, 2021, 2:04:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
