Total posts in this thread: 4
Previous Thread This topic has been viewed 836 times and has 3 replies Next Thread
GregTheHun
Worked on previous installations of Linux, now won't load
So, it appears even using the same hardware as before. I get stuck on the splash image and now it won't even load.
Here are my specs (I know what you're going to say, but it had worked before):
CPU: 6-Core AMD Phenom II X6 1100T (-MCP-) speed/min/max: 803/800/3300 MHz
Kernel: 5.13.19-2-MANJARO x86_64 Up: 10m Mem: 2684.8/16004.9 MiB (16.8%)
Shell: fish inxi: 3.3.09
Here is the output when run from the command line:
OpenJDK 64-Bit Server VM warning: Ignoring option --illegal-access=permit; support was removed in 17.0
Java 3D: implicit antialiasing enabled
Exception in thread "J3D-Renderer-1" java.lang.IllegalAccessError: class javax.media.j3d.X11NativeConfigTemplate3D (in unnamed module @0x7e0ea639) cannot access class sun.awt.X11GraphicsConfig (in module java.desktop) because module java.desktop does not export sun.awt to unnamed module @0x7e0ea639
at javax.media.j3d.X11NativeConfigTemplate3D.isGraphicsConfigSupported(X11NativeConfigTemplate3D.java:1
80)
at javax.media.j3d.NativePipeline.isGraphicsConfigSupported(NativePipeline.java:3341)
at javax.media.j3d.Renderer.doWork(Renderer.java:533)
at javax.media.j3d.J3dThread.run(J3dThread.java:275)
Any further information I can grab if you need me to run a command.
Thanks in advance.
[Nov 30, 2021, 9:06:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Worked on previous installations of Linux, now won't load
Sweet Home 3D can't run with Java 17 at the moment. Use an other Java version or the installer version available at Download page.
[Dec 1, 2021, 11:25:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
GregTheHun
So, it looks like I have a few installed, is there a way I can specify which one to use?
extra/icedtea-web 1.8.8-1 [installed]
extra/jdk-openjdk 17.0.1.u12-1 [installed]
extra/jdk8-openjdk 8.u292-1 [installed]
extra/jre-openjdk 17.0.1.u12-1 [installed]
extra/jre-openjdk-headless 17.0.1.u12-1 [installed]
extra/jre8-openjdk 8.u292-1 [installed]
extra/jre8-openjdk-headless 8.u292-1 [installed]
[Dec 1, 2021, 4:20:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GregTheHun
Nvm, uninstalled newer java version, and for Linux (Manjaro) specifically had to specify JAVA_HOME environment variable. (I use fish shell, probably works in bash)
[Dec 1, 2021, 4:34:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2022 eTeks - All rights reserved
