Total posts in this thread: 4
Previous Thread This topic has been viewed 738 times and has 3 replies Next Thread
Kodish
Canada/ From London uk
Photo rendering speed on a MacBook Pro
Photo rendering speed on my MacBook Pro is so slow like it takes hours at 2000 pixels high quality.
See below my info : help much appreciated.
I'M, RUNNING SH3D VERSION 6.6.1 ON;
MAC OS CATALINA
VERSION 10.15.7
MACBOOK PRO RETINA 15INCH MID 2014
PROCESSOR 2.8 GHZ QUAD CORE INTEL CORE i7
MEMORY 16GB 1600MHZ DDR3
SSD HARDRIVE
GRAPHICS NVIDIA GEFORCE GT 750 M 2G
INTEL IRIS PRO 1536 MB
WHY IS IT SO SLOW ?
[Nov 29, 2021, 4:37:18 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Photo rendering speed on a MacBook Pro
Rendering speed depends on a combination of factors:
1 - the processor of your computer and to a lesser degree the amount of memory available to SH3D;
2 - the size of the image to be rendered;
3 - the number of polygons to be rendered;
4 - the number of light sources present in your design;
5 - your rendering settings.
1 - No surprise here that a faster processor with more cores (or threads) will deliver speedier results. For memory usage see: How can I adjust the memory used by Sweet Home 3D?
2 - Same with size: a 400x400 pixel image will be rendered in less time than a 1000x1000 pixel image.
3 - This one is more complex:
3a - Highly detailed models will take longer than simple models (but will give better results). A 10 MB model of a coffee machine will take longer than a 100 KB model. Trees and other plants tend to have many polygons, so take much time.
3b - The program takes everything in your model into account, whether it's in your field of view or not. So, if you want to make a render of the kitchen, rendering is speeded up if you make models in all other rooms (and levels?) invisible.
3c - Large textures take more time than small textures (but will give better results).
4 - A design with one light source will be ready in less time than the same design with 10 or 20 light sources.
5 - Your rendering settings greatly influence the time rendering takes. Setting quality to level 3 or level 4 makes a big difference. If you want (near) photorealistic results and are using EnkoNyito's plugin, you have more options to improve rendering quality. Setting higher values for "anti aliasing" will increase rendering time considerably.
All of the above have an influence. Only you can decide which factors are more important.
[Nov 29, 2021, 7:57:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Kodish
Hey H thanks for this info really appreciate it smile
My Renders are coming out really nice its just they can take hours to
process , hopefully i can get this sorted with this new info
thanks again
Paul
[Nov 29, 2021, 8:25:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
After all the suggestions proposed by Hans, you could also try YafaRay rendering plug-in to speed up rendering.
[Dec 1, 2021, 3:19:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2022 eTeks - All rights reserved
