Previous Thread This topic has been viewed 4061 times and has 9 replies Next Thread
stef.salmon
Strange Lines on 3D Layout
I have done a simple 3D layout using the YafaRay engine, but I have a few strange lines which look like shadows.
I'm using a solid black for the floor and a solid white for the sky with the time set to 1am.
https://www.dropbox.com/s/83j5nyvv0z4nljb/Fac...g_T_L7_N1_Layout.png?dl=0
Any ideas?
Thanks in advance.
[Oct 22, 2021, 2:57:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Strange Lines on 3D Layout
The lines top left and top right??
Try to uncheck "ceilings" and see if they disappear.
If ceilings are needed, make sure all <!> walls have the same height.
[Oct 22, 2021, 3:10:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stef.salmon
Hi Hans,
Yes that's what it was.
The outer wall was only 50cm high, that's because the layout is in the middle of the building and I was trying to encapsulate the floor by making the walls smaller and creating a room to shade in with a texture.
If that makes sense?
All the other walls are 250cm high.
Thanks.
[Oct 22, 2021, 4:03:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stef.salmon
I'm getting a bit fed up with these lines appearing. The time is set to 1am in the morning and I'm still getting shadows.
https://www.dropbox.com/s/w23w0fnhsxvdxbg/Fac..._Level_01_Layout.png?dl=0
Any ideas how to stop this?
Thanks in advance.
[Dec 17, 2021, 3:40:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hard to say without access to the original file.
Most often these are ceiling parts, caused by ceilings between walls of uneven height.
Uncheck "Ceilings" in all rooms to (try and) solve it.
[Dec 17, 2021, 4:12:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I think this is due to large rooms. Does it happen with both the default and YafaRay rendering engines?
[Dec 17, 2021, 5:27:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stef.salmon
Hi Hans,
If I sent you the project file would you be willing to take a look?
Thanks, Stef
[Dec 20, 2021, 4:12:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Of course
[Dec 20, 2021, 6:22:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stef.salmon
Hi Hans,
Thank you very much.
https://www.dropbox.com/s/2x215m76w78y062/Fac...Level_01_Layout.sh3d?dl=0
Regards, Stef
[Dec 21, 2021, 8:26:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stef.salmon
Hi Hans,
Do you know where I can get a closed door from, as like you said I think that is what is causing these random shadows?
Thanks.
[Jan 18, 2022, 12:54:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
