Total posts in this thread: 5
Previous Thread This topic has been viewed 4766 times and has 4 replies Next Thread
luigisoft
Re: 90° Drehen vom ganzen Plan?
Hans,
Jumping forward 8 years, I am using Win 10. Into which folder in Win 10 should the plugins be installed. I am in the process of installing the plug in RotatePlan, but the folder described in the documentation is for Win 7/8 and this folder does not exist in Win 10.
Many thanks,
Trevor.
[Oct 22, 2021, 12:08:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
luigisoft
PS I am using Sweethome 3D, version 6.6.1., which I bought from the Microsoft Store.
Trevor
[Oct 22, 2021, 12:17:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
luigisoft
PPS,
continuing with this thread, I double-clicked on the file RotateHomePlugin.sh3p, which loaded the plugin into Sweethome. Version 6.6.1 states, that the RotatePlan plugin was successfully imported into Sweethome, but it does not appear in the drop-down list under Plan. This list goes down to the bottom of the screen. The last function on this list is Verkleinern. (I'm using the version in German). Rotate plan should appear below Verkleinern.
An ideas why Rotate plan is not appearing in the list?
[Oct 22, 2021, 12:35:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
When importing a plug-in, a window appears that says something like "plug-in will be available at next start-up"...
[Oct 22, 2021, 1:04:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
luigisoft
Thank you for your reply.
That message appeared after I had double-clicked on the plugin, but is not shown in the drop-down list for Plan after I restarted Sweethome.
Regarding the file path for Win 10, I found this C:\Users\Acer\eTeks\Sweet Home 3D\plugins.
Is this the correct path?
[Oct 22, 2021, 4:26:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
