New Zealand
Exterior render is being rendered without ceiling + ambient is too strong
Hey guys,
This image is being rendered as if there is no roof/ceiling for the house, which is not very realistic. I have checked the "show ceiling" option for each room, but it doesn't seem to do anything.
Also, some part of the render is overexposed with little/no light added. I could reduce the strength of the sun by changing the time. but it also changes the position as well. Is it any way to adjust the position and strength individually?
Re: Exterior render is being rendered without ceiling + ambient is too strong
You could try to adjust the hour and season to ensure the sur is at the top.
You can change the seasons changing the date, and also changing the compass parameters. To can find some tips for the kind of renderings you want (yours is not bad, yet) in this article.
New Zealand
Hey thanks for the reply. I have been playing with invisible boxes, and set the import setting for it as staircase.
I draw the box first on the first level and then add level 2 suggested by the article. I then draw a room to add the floor. However, the floor is still visible. Any ideas?
