Total posts in this thread: 5
Previous Thread This topic has been viewed 4743 times and has 4 replies Next Thread
LaundrySolutions
Australia
Can't get SH3D to run on my new Surface Pro X
Hi all,
I'm experiencing the same issues as a lot of other people re the fatal error in the rendering system etc.
I've tried a range of workarounds including 32bit, running it with the ini file for Directx etc and have tried running it within Java etc but to no avail.
Has anyone got any other ideas - I'm desperate
Thanks
Sean
[Aug 28, 2021, 2:28:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Can't get SH3D to run on my new Surface Pro X
If none of the solutions proposed in the FAQ works, you could try to set com.eteks.sweethome3d.j3d.useOffScreen3DView property to true, by writing the line
-Dcom.eteks.sweethome3d.j3d.useOffScreen3DView=true
in SweetHome3D.l4j.ini
[Aug 28, 2021, 1:21:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
LaundrySolutions
Australia
Thanks Emmanuel,
I give it a try and let you know how it went.
Cheers
Sean
[Sep 1, 2021, 7:25:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
LaundrySolutions
Australia
biggrin Re: Can't get SH3D to run on my new Surface Pro X
Hi everyone,
Just an update, tried installing V7 and had the same result.
If anyone has any other ideas.....
[Jul 21, 2022, 1:18:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Your Surface Pro X contains an ARM processor, not an Intel processor, right?
If it's the case, the installation program should be able to install a working 32 bit version running with DirectX, but I have no idea if it actually woks because the user arm64appcompatguy never answered about it in this thread.
[Jul 21, 2022, 2:19:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
