Total posts in this thread: 9
Previous Thread This topic has been viewed 15182 times and has 8 replies Next Thread
ddt57
indonesia
Raise the ground floor
How to raise the ground floor to 10 cm..? like skecthup with pushpul/down
tks
[Aug 8, 2021, 3:09:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Raise the ground floor
Onder a level at 10 cm elevation and build your house/room there.
[Aug 8, 2021, 11:22:12 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ddt57
indonesia
but this is on the ground floor, not on the second level, because there is no elevation
[Aug 8, 2021, 12:45:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It isn't exactly clear what you want. You could add a level at -10 cm and the house would be below the ground...
[Aug 8, 2021, 5:56:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ddt57
indonesia
sorry, I mean how to thicken the floor to 10 cm at level 0
[Aug 9, 2021, 7:17:12 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Assuming you don't have any levels yet:
1 - add a second level, this creates two tabs for the levels
2 - select and double click the tab for the lower level
3 - change the floor thickness.
[Aug 9, 2021, 7:22:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ddt57
indonesia
thanks for explanation, very helpful
[Aug 10, 2021, 4:59:27 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ddt57
indonesia
how to make a hole in the wall..?
[Aug 10, 2021, 5:53:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Hi ddt57,
Did you notice the different tips in the blog? Many of them might also help you.
[Aug 10, 2021, 9:47:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
